AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Titleblock / WDL
2 REPLIES 2
oveimariemamn
1196 Views, 2 Replies
Titleblock / WDL
Is it possible to have two different Titleblocks in the same folder and with two WDL-files. If possible how do you connect the correct WDL file to the Titleblock?
2 REPLIES 2
Nata_ly
in reply to: oveimariemamn
Hi!
Yes, you can, but for certain project - certain wdt and wdt.
ACE looks the following order for this files:
1. <projname>_wdtitle.wdl (wdt) - where <projname> matches the name of the active project in the same folder as the project WDT file.
2. default_wdtitle.wdl (wdt) - in the same folder as the project WDT file.
3. default_wdtitle.wdl (wdt) - in a folder in the AutoCAD Electrical search sequence.
So you could have <projname>_wdtitle.wdl and default_wdtitle.wdl in the project folder. But ACE will use only <projname> files.
oveimariemamn
in reply to: Nata_ly
Thank you Nata_ly, now i'm a little clevererSmiley Happy
”Boost
