AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
titleblock --> Drawing Properties
5 REPLIES 5
sjoulaei
285 Views, 5 Replies
I am working on an upgrade project. we have some drawings in old version of ACAD with title blocks and attributes on it.
I want to have some attributes as my drawing properties ( like Drawing Descriptions and drawing numbers etc.) and I'm wondering to know is there any way to reverse mapping from tblock to drawing properties?
thanks
Saeed
5 REPLIES 5
in reply to: sjoulaei
Go to Projects - Title Block Setup and choose .wdt
Select Pick Block and select your old title block, then right clock and
click OK
Next select Pick next to the project description line you wish to use for
that description.
Pick the attribute you need for that description line. Repeat until all your
project details for the drawing are selected.
Click on Drawing Values down near the bottom right of the dialog box.
Do the same as before regarding Dwg descriptions, numbers and so on.
When finished, click OK.
This creates a .wdt file which is associated with the project you are
working on.
The only other method would require you to copy the title block to a blank
dwg and explode the title block in the new dwg.
Go to Projects - Title Block Setup and choose WD_TB Attrib.
Follow the steps as above then save the title block using a different
location.
Next you need to Swap the title block by going to Components - Component
Miscellaneous - Swap/Update Block
Select Swap a Block - one at a time, then Browse to new block. Click OK to
continue once that's done.
Browse to the new title block and select it, and click open to use this
block.
Next you select the old Title Block on the dwg. Right click to exit the
command.
Go to dwg properties and fill in your dwg data and Project Descriptions to
fill those in.
Do a title block update to transfer the data to the dwgs.
Regards Brad
wrote in message news:6035011@discussion.autodesk.com...
thanks
Saeed
sjoulaei
Brad,
Thanks for your comment, but my question was about bringing values from old drawings to new system .
Actually, I have changed my old tblock to new one with everything in it but when I want to see them in Drawing Properties (right click in the project management section on drawing and click on drawing properties...).
Why I want it is to use sheet no ( that is not sequential for whole project ) and DWG No and Drawing Descs ( for drawing list Index ).
Cheers,
Saeed
Hi everybody,
I dont know why I could not post a new threat out there, it says server error 500 somethings when I hit the button, so I borrow this threat to post my inquiry.
I am totally new to AcadE and would like to learn how to use the software. I am following the Getting Started and the User Manual included in the DVDs, the files teach me well except I dont know how to create a title block from scratch without using any existing templates.
I tried to use the symbol builder to create a title block but I am stuck in how to add title block attributes into the drawing. As I understand, template files are main component of the acadE drawings. Please give me some help.
Thanks in advance.
Hi everybody, I dont know why I could not post a new threat out there, it says server error 500 somethings when I hit the button, so I borrow this threat to post my inquiry. I am totally new to AcadE and would like to learn how to use the software. I am following the Getting Started and the User Manual included in the DVDs, the files teach me well except I dont know how to create a title block from scratch without using any existing templates. I tried to use the symbol builder to create a title block but I am stuck in how to add title block attributes into the drawing. As I understand, template files are main component of the acadE drawings. Please give me some help. Thanks in advance.
”Boost
