Solved by dougmcalexander. Go to Solution.
What you seek is normal. That is how I set my title blocks up. It is how I teach it in my classes as well. You can have problems if some of your attributes are nested in a block. I keep everything, border and attributes, at the same level. I use Title Block Setup to map everything. I prefer Method 2, so the mapping is stored inside the template. Drawing values, DD1, DD2, and DD3 of course point to attributes I have positioned as drawing description information, which will be unique for each drawing. I use DESC1, DESC2, and DESC3, but you could use TITLE1, TITLE2, and TITLE3 if you prefer. Save this drawing as a .DWG file. Now, insert it into a blank drawing that you create using the acad.dwt template. Add Drawing Properties, Wire Types, and assign colors and line types to the layers, if you don't like the defaults. I usually change the LOCBOX layer to dash dot line type (per IEC but works in U.S. as well) and set the color to green or blue. You will need to create this layer, or insert a location box from the menu and Electrical will create the layer.
Delete any blocks you have inserted for testing purposes and purge only unused blocks. Do not purge anything else. Finally, save this drawing as a template (.DWT).
