If it's an existing ACADE project just from an earlier version, use the Copy
Project function, then just remove any dwgs you don't need. Change the
Descriptions and run Title Block Update.
If the dwgs are plain ACAD, and there are no other dwgs in the project, go
to Projects, Title Block Setup and select the
.DWT choice. go
through and set up the title block attributes and you are set.
I have never mixed different title blocks within a project so I'm not to
sure if you can have two different title block setups in the one project.
Regards Brad
wrote in message news:6344394@discussion.autodesk.com...
How can I take an existing Autocad Title Block and incorporate it into the
Auotcad Electrical 2010 - Project format to update all Drawing Title Blocks
in one Project.
I have an upcoming Project were I will copy twenty-eight (28) existing
drawings and all that will change is Drawing numbers, Drawn By, Checked By
and dates.
Thanxx for any Help in Advance
