Hello
What is the procedure to apply Project Title block properties to the drawing sheets in one shot? i know each drawing sheet can be applied with project setting individually but i would like to know at a time applying to all the sheets.
Thanks!
Solved by Avd650. Go to Solution.
Solved by lturley. Go to Solution.
It took me a few versions of ACE and a forum post to discover this, so don't be embaressed!
Basically, use the SHIFT/CTRL key to highlight multiple drawings in the project window. Right click and apply project default settings 😉
Hello
Thanks for the answer. it works!. One more question, is it possible to change the Title Block format? I mean, if i have 5 sheets of drawings and out of 5 sheets 2 sheets i made with differant Title block format, can i change it as remaining 3 sheets format. I don't think it is possible to change the Acad Block itself. Please let me know...
Just mark tittle block on one page that you want to copy from, CTRL+C and go to page you need to update. Delete the tittle block there and paste the other one with coordinates at 0,0,0.
It should work. You need to run tittle block update...
DK
DK has advised you well. I would only add that, if you need to replace multiple title blocks in a project, you can use the Swap/Update Block utility. Select Project-wide. My title block is built into my drawing border and is saved as a template. I save as both a template (.dwt) and a drawing (.dwg) file. Use the drawing file as the replacement. The bottom line is that you think of the title block as another component symbol. After all, you are essentially inserting drawing files into drawing files when working with AutoCAD blocks.
Hello Jay!
Did you mean your attribute format?
Have you ever used the command ATTSNYC?
It will update the other title blocks to look like the title block attribute format that you selected.
The attribute format you wished to copy must be the format in your block. You will know this by going in your
block using REFEDIT.
Make sure you try this command on a test dwg file. You can undo anyway. Isn't UNDO command great?!!
Rose
The red descriptions indicate that you have two or more attributes with the same name....
They will work as normal so don't worry about that, but it would be advisable to go through the attibutes and change the names of the duplicates.
Regards Brad
Brad Coleman, Electrical Draftsman
Doug,
The project wide titleblock swap did work in older versions, but I can not seem to get it to work in 2016??
