AutoCAD Electrical Forum
Title Block Attributes
4 REPLIES 4
281 Views, 4 Replies
Does anyone know of a way to combine multiple drawing properties into one attribute on the title block. I'd like to combine my Drawing Number and Sheet Number values and insert them into one attribute using the Title Block update and attribute mapping files. Any suggestions? Thanks!
4 REPLIES 4
dougmcalexander
Just place an attribute for drawing number and an attribute for sheet number
next to one another. Right justify the drawing number attribute and left
justify the sheet number attribute. I've done it and it works fine.
wrote in message news:5877369@discussion.autodesk.com...
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
The problem is that I don't want to have to change my title block and update the 300 drawings that I've already created!
You could always try what I did. Add all your drawing to a single new
project, and then doing a project wide block update of your title block.
Just make sure you have the new title block set up correctly as a block...
I found it worked a treat, apart from having to go into some drawings to
reconnect their field associations..
Regards Brad
wrote in message news:5877422@discussion.autodesk.com...
dougmcalexander
I thought you were creating a new title block. If you already have one and
need to revise it, just use the Update block command after you modify it.
Doug McAlexander
”Boost
