The project consists of several identical cabinets. I created a scheme for the first cabinet, the location code SHK1.
Scheme on all sheets of the project are the same, only the codes locations in the components on different sheets are different: on the second sheet SHK2, on the third sheet SHK3 etc.
What tools easiest way to create schemes for other cabinets?
Solved by Icemanau. Go to Solution.
Easiest way that I have found is a bit of a work around as I'm not aware of an ACADE funtion to do this.
Go to Windows and copy the first panel dwg/s and change the file names to what is required for the additional panels.
Open each dwg in ACADE and start the tool that copies Installation/Location codes.
Select the Installation code and enter the code for the second panel.
Deselect the Location code. Click OK then type ALL on the command line and hit enter. This selects all blocks on the dwg.
Hit enter again to finish the selection process and let the command run to it's finished.
Save the dwg before doing anything else.
Make sure you have the correct project as the active project. Now ADD ACTIVE dwg to the project.
Rrepeat as required for any additional dwgs.
After adding the final dwg, do a Project Rebuild.
You now have a project with multiple identical panels without having to redraw each dwg.
Regards Brad
Brad Coleman, Electrical Draftsman
