AutoCAD Electrical General Discussion
Valued Contributor
junkinjam
Message 1 of 6 (407 Views)
Text style for wire color/gauge
407 Views, 5 Replies
02-04-2013 10:53 AM
I've been using Electrical 2010 for a little while now, but for the life of me I cannot remember how to change the text syle of the wire color/gauge leader. It comes in on the 'standard' layer, but I want to use 'simplex'. How do I change it? I can't seem to find any information for this particular issue.
Thanks in advance. :smileyhappy:
Julie
Go to the Format menu and select the Dimension Style.
Now select the Text tab and you can change the font, style, size and a few other items. Other tabs allow you to change other settings to do with dimensioning.
Regards Brad
Active Contributor
btackes
Message 2 of 6 (395 Views)
Re: Text style for wire color/gauge
02-04-2013 01:43 PM in reply to: junkinjam
"The label text size follows the current AutoCAD DIMTXT setting and the arrow size defaults to the current AutoCAD DIMASZ setting."  Font style is DIMSTLYE
Valued Contributor
junkinjam
Message 3 of 6 (391 Views)
02-04-2013 01:51 PM in reply to: junkinjam
Yes, I did read that. But where would I find the DIMTXT setting? If I enter 'dimtxt' on the command line it only gives me the option of changing the text size, not the font.
Thanks.
Active Contributor
btackes
Message 4 of 6 (387 Views)
02-04-2013 02:01 PM in reply to: junkinjam
Font style is DIMSTYLE then click modify
Icemanau
Message 5 of 6 (386 Views)
02-04-2013 02:03 PM in reply to: junkinjam
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
Valued Contributor
junkinjam
Message 6 of 6 (359 Views)
02-06-2013 04:46 PM in reply to: Icemanau
Thanks! That was what I needed :smileyhappy:
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
