Hallo
Hope somebody can assist, I'm using autocad electrical 2014...
I tried everything to show connections on terminals, The issue is that I got a three phase supply going to terminals, then from the terminals it daisy chain between componenents, but when using the terminals editors it shows there is connections to terminals, it then adds additional terminals to my project which is not correct. can somebody please let me kow where I'm going wrong.
Solved by rhesusminus. Go to Solution.
Hallo
Thanks, I've done the rebuild as per your suggestion, but still didn't solve the problem, maybe I'm missing some information regarding the source destination and terminal connections, I've done the data trace and it doesn't seem to be connected, I also took a snapshot of the Q112 that you can see don't have any terminals, how does autocad decide if the wire is connected to terminals or to components? (As you see this is not connected to a terminal)...
Hallo
OK below is the wire connection sequence, I'm not to sure what I'm looking at, but at the end the only connection to Q112 should be the circuit left of it and the next page Q131, so assume I'm doing something very wrong... Can you please explain just how autocad decide on either components or terminals?
Below what does the second box showing? (Direct-toTerminal secondary Sequence)?
Hallo
Thanks for all the assistance this far...
OK, i've changed as per your suggestion and also done a project rebuild, I extracted a couple of pictures from the project, it should be easier t understand the circuits in more detail now... The issue is that the circuit on page 010 is connected to between MCB Breaker and to the terminal, then the Fuse connections is also directly under the breaker directly to the fuse, but for some reason autocad still thinks there is a connection between the fuses to the terminals, which is not correct, but I hope the picutres will explain a bit better?
What codes are you using for the signals?
Are they unique for each source/destination pair?
It's hard for me to say what it is without having a closer look.
If you are able to zip it up and mail it to me, I'll take a look. (thl @ ctrlaltel.com) (remove spaces)
Hallo
As per our discussion, please find source and destination project in folder, please let me know if this is OK or do you need anything else.
I tried a attachement but file just over 7mb, please find link below:
https://drive.google.com/file/d/0B7r1S9YLTX85alkzZ2lkUC1KYmM/view?usp=sharing (Folder called Lasher_990064)
Thanks for the effort
First of all, nice drawings!
The "problem" here, are the usage of the "dots" at the wire tees. When AcadE trace the connections from the terminal, and reach a "dot", it will sometimes go this way, sometimes that way, and that is what's happening here:
To fix this, theres a couple of things you can do.
If you now take a look at the TSE, it should look like you want it to:
Hallo
Thanks a million for all you effort in assisting.
I'm going to try the wire trees instead of the dot, will give you feedback soon..
Thanks for the compliment on the drawings, this is the first time I'm using electrical and this the reason for the questions.
Best Regards,
Hallo
Thanks for the assistance, after our conversation I just played around with the wire sequence, not perfect but at the end it shows on the terminals what I want to display, I'm not to concerned about the cable to and from report, at least at the end I know if I want to have it perfect I need to change the dot tree connections. for now I'm good.
Thanks a lot...
I got another question regarding creating panel symbols and include in icon menu.. but will start another thread.
Thanks again.
