I'd like to use terminal with vertical tags/attribute. I try to modify circular terminal (file block name "ht0002.dwg"), i rotate vertical tags/attribute in block editor (take a look at image) but when i choose this terminal in catalog ACE drawing it with orizontal tags/attribute . Why?
1)did you place the old symbol in the drawing your attempting to use the new terminal
as acade looks for a block defninaition in your drawing before it goes of looking for the block in the the synbol libary ?
try purging the drawing of unused blocks
2)did you save the terminal in the correct location ?
3) have you tried resetting the attributes type "attsync" at the comand prompt
