AutoCAD Electrical General Discussion
Valued Contributor
0 Kudos
Post 1 of 3
Terminal/Wire number problem
76 Views, 2 Replies
05-04-2004 06:37 AM
How do I keep wire numbers on each side of a terminal to remain the same after inserting a terminal? Typically, a wire being connected to a terminal strip carries the same wire number as the terminal block.
Distinguished Contributor
1 Kudo
Post 2 of 3
Re: Terminal/Wire number problem
05-04-2004 07:39 AM in reply to: tomw47
It's rather easy. The last part of each wirecut attribute has the same value. Example: The left wirecut attribute is X4TERM01 and the right atrribute is X1TERM01. And if you want top and bottom wirecut points, just be sure that thay have the same number in the last part. After you edit your terminal symbol as above, the wire numbers will "pass through" the terminal as remain the same.
*John Pullen
Post 3 of 3
05-04-2004 10:08 AM in reply to: tomw47
At a very basic level, don't use the terminal blocks on the far right side on the menu, those cause the wire number to change. "tomw47" wrote in message news:1275601.1083677905062.JavaMail.jive@jiveforum2.autodesk.com... > How do I keep wire numbers on each side of a terminal to remain the same after inserting a terminal? Typically, a wire being connected to a terminal strip carries the same wire number as the terminal block. > Thanks
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
