AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Terminal strip wire numbers won't move with terminal strip
4 REPLIES 4
pgstein
223 Views, 4 Replies
It appears that after I rebuild a terminal strip that I can no longer move it with the move command without the wire numbers staying where they were.
Is this some kind of known bug? Or am I doing something wrong?
Paul
4 REPLIES 4
srobinson
in reply to: pgstein
It seems like this is something that happens every time after you insert a TS. I just close out autocad and open it up again. It always works after that.
pgstein
Glad to see its just not me then. Atleast here, it seems to only happen after a rebuild. Closing and opening AutoCAD really isn't that practical. Any ideas?
I found that if I re-inserted the tb in the correct position it removed the
old one. A bit cumbersome but it gets away from having to restart Autocad.
Regards Brad
wrote in message news:5877883@discussion.autodesk.com...
Any ideas?
pgstein
That does work. The only thing is that reinserting the terminal strip erases all of my BOM item numbers, therefore it would be much easier to be able to just move it instead.
”Boost
