Still getting the hang of this... and it wouldn't hurt if I knew more about controls in general... but;
I have a terminal strip I built from my schematic with about 12 terminals in it. Added 4 accessories; 3 Relays and a Breaker. I inserted it into my panel layout and everything looked good. Then I went back into the T strip editor for more work... the 4 accessories now each show up as individual T strips available for editing, instead of staying with the strip I added them to. I've never seen this before, and I assume I did somehting goofy... any idea what I might have done?
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
Solved by testsubject. Go to Solution.
Chris,
I am not sure why you are seeing what you are seeing.
I typically would insert the relays and breakers independently of the terminal strip. I do this using Schematic List. This then keeps track of all the components that have been inserted so far letting me know if I forgot any.
Thanks Bob,
This is what I started doing after I started to see this behavior.... I think if I did this every day instead of about once every 6 weeks, I'd get better at it! 😄
Chris Benner
Hi Chris,
I have seen this a few times before.
In the few cases I have seen, it was how the symbol was authored.
Instead on creating the the symbol as a "Panel Terminal" the symbols were created as Horizontal terminals, or Vertical terminals (both horizontal, and vertical are for Schematics).
For the Terminal Strip Editor the terminal blocks should be authored as Panel Terminals.
I have also seen this happen when the symbol has errors (normally its missing an attribute, but is still a panel term).
I hope this helps,
James Alger
