AutoCAD Electrical General Discussion
Active Member
Nitro
Message 1 of 2 (43 Views)
Terminal Strip Help
43 Views, 1 Replies
06-24-2004 11:05 AM
I am using an 18 terminal strip in 2 ways. #1 I created a symbol block with terminals 1-18. This is a 24v bus so I tied a wire from term 1 to 18 so that all wires exiting the strip generate the same wire number. How can I do this without the wire tie wire? #2 The same 18 term strip is shown on many different sheets of my drawing. I created a block showing one terminal. The first instance placed is a Parent and all others are children. The problem with this is that the wire I used to tie them all together shows up on the from-to list. (This is the internal jumper.) The second problem is the BOM shows Qty 18 instead of the actual Qty1. Any hints on how to show terminal strips and have the BOM and from-to list accurate?
Tim
*John Pullen
Message 2 of 2 (43 Views)
Re: Terminal Strip Help
06-24-2004 12:56 PM in reply to: Nitro
#1: Use the Component Misc/Internal Jumper command. #2: Did you put a CAT attribute on the child blocks? "Nitro" wrote in message news:13085390.1088100361463.JavaMail.jive@jiveforum1... > I am using an 18 terminal strip in 2 ways. #1 I created a symbol block with terminals 1-18. This is a 24v bus so I tied a wire from term 1 to 18 so that all wires exiting the strip generate the same wire number. How can I do this without the wire tie wire? #2 The same 18 term strip is shown on many different sheets of my drawing. I created a block showing one terminal. The first instance placed is a Parent and all others are children. The problem with this is that the wire I used to tie them all together shows up on the from-to list. (This is the internal jumper.) The second problem is the BOM shows Qty 18 instead of the actual Qty1. Any hints on how to show terminal strips and have the BOM and from-to list accurate? > Tim
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
