Yep, I've come across this as well. The only solution I've found is to
Re-Insert the strip.
Regards Brad
wrote in message news:5769056@discussion.autodesk.com...
Does anyone else have this problem:
I insert a terminal strip. I can move it, everything is ok.
Then I do a rebuild of the terminal strip. I try to move the terminal strip
but the attribute stubbornly stay at their original spot. I've tried it with
move component and the regular AutoCAD move, it always has this problem. I
can move the attribute manually or rebuilt the terminal strip to fix this
but that's not very efficient.
I included a before and after in the attachment.
Sven Kloe
ck
Electrical Network Design
