HI does anyone know how to customize the terminal block strip to obtain finally the position and the sheet reference in my terminal strip
thank's
Solved by dougmcalexander. Go to Solution.
When you use terminal strip editor there are multiple selections for additional tags. Did you look at the available selections? If so and you did not find what you wanted, try adding something like %S%W to one side or the other. If all else fails, try looking up replaceable parameters in the help files.
Scott
%S isn't an option for wire annotation. Perhaps Autodesk will consider adding that as an option. %D is redefined as term description for wire annotation so adding the sheet number to the Drawing Number field would not help either. The only thing I could suggest is to base your wire numbers on sheet/line reference. This would indirectly give you the sheet number as part of the wire number. See the attached example. The wire number format for the drawings is %S.%N with a suffix of .1 .2 .3 etc., as shown in the attached.
Good solution thanks
Standard and bespoke PLANT3D Training and ACAD Training and ACAD ELEC Training
