hello all.
I have in my electrical diagram fuse terminals that cuts the number of wire.
when I do desire a graphical representation of my terminal, I can not do a show on the representation of the two wire numbers on each side of the terminal, but I can see the two numbers in the terminal editor.
you had someone there is problem? there is there a solution?
thank you for your help
First of all, check that the footprint block has all the correct attributes on it. Also make sure that any wire number attributes on each side are labelled for the appropriate side.
If that doesn't work, try to post a screen shot of the dwg and TSE and the footprint block to the group.
Regards Brad
Brad Coleman, Electrical Draftsman
I agree with Brad. You have to be sure that all the attributes are on the block. Also, make sure they are visible by editting the attributes of the block and check that all layers are turned on.
