AutoCAD Electrical Forum
Terminal Block Jumpers
0 REPLIES 0
Message 1 of 1
ronbotkin
302 Views, 0 Replies
I finally came up with a way to show the terminal block jumpers that you cut to length.  I created a din-rail for the jumpers.  I put in the size I wanted and then created a new drill hole drawing that fills in the link between terminals.  I added the fields to change the color and you can also change layers if you want.  Remember to put in the maximum length of the jumper and it will break it into more than one if it excedes the maximum length.  I didn't figure out how to remove the slot that it draws, but I made it very small and it serves as a visual reference.  So far this is the best idea I've had for them.
0 REPLIES 0
”Boost
