The Terminal Strip Editor is used to piece together all the separate DIN mount terminal blocks into a single graphical or tabular strip. It will not create a footprint. It calls up footprints itself from the footprint_lookup.mdb. If you have device that is one block with multiple points, that happenes to be applied as a terminal strip, just create a standard footprint using the Symbol Builder. That type of symbol would be handled like a circuit board with a terminal strip mounted on it. Just draft a rectangle in the basic shape of the devce and add attributes. It should work fine. You can even add wire connection attributes so your wire information can be annotated from the schematic. This is an option in Symbol Builder.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
