AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Terminal Association
0 REPLIES 0
Message 1 of 1
gcsjlewis
318 Views, 0 Replies
I have a Phoenix 2-high terminal block (Phoenix p/n 3031429).  On my schematic drawings I have one terminal coming over from the power line with a terminal number based on rung number, and the I have another terminal coming off from a PLC address.  When I go to associate these terminals (It doesn't matter which order I click) It makes the "master" terminal (or top point) based off the rung number.  And I want to make the PLC address the top, and the terminal off the power line bottom.  So I have to manually change this (Edit component, add/modify under the modify properties, then click on the move up button) for each terminal "group"  And some of my drawings will have 80 PLC Addresses, so doing this is very time consuming.  Is there a way to make the "master" terminal always see the PLC terminal as the master and put that on top?
0 REPLIES 0
”Boost
