This description is displayed in the Startup dialog or the Create New
Drawing dialog if you have your options setup to display the Startup dialog.
To see these descriptions:
1) Go to the Options dialog and select the System tab
2) In the General Options section, use the pop-down list next to Startup to
select the option 'Show Startup dialog box'
3) Now when you run the New command you will get the Create New Drawing
dialog and if you select the 'Use a Template' button, all the current
templates will be listed and ifyou highlight one of them, the description
will show in the bottom of this dialog.
Steve
wrote in message news:5145753@discussion.autodesk.com...
When i go to add a new template, i type in a brief description of it but
cannot locate where the description is ever used when selecting templates.
The dialog box for new or open file can have a column shown that is labeled
description but the autocad description doesn't show up. any ideas where i
find the template description anywhere after i enter it?
