AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
TEMP DEBUG MSG
3 REPLIES 3
pmccutcheon
345 Views, 3 Replies
TEMP DEBUG MSG
Autocad Electrical 2012 SP1 on XP SP3 32bit
Frequent problems where database services not working.
-surfer will not work, doesn't find anything in project
-catalog lookup does not work -- says it cannot find a component table, but we are setup to always use MISC_CAT -- we don't use component tables
-database full rebuild does not work -- get error message TEMP DEBUG MSG *** DIFFERENT FIELD COUNTS IN TABLE WNETLIST
I don't see a pattern to the failure.
AE will work fine for a while, then at some point, the database features/functions quit working
Only way to recover seems to be to close AE and then reopen
Seems like it cannot read DEFAULT_CAT.MDB, and the "scratch" dbase as well.
Tags (1)
3 REPLIES 3
Icemanau
in reply to: pmccutcheon
Several causes for the DB Services failing that I know of.
1. Anti virus is doing active scanning of the drive.
2. Someone has moved or modified a file the DB Service is monitoring. This usually applies to networked systems.
3. You have used a plain ACAD command to do something that causes the DB to fail.
4. Faulty network infrastructure
To test the first item, disabel your antivirus for a session and see if that helps. If it does, try a different A/V program.
The second item can be a bit more of a pain to track down.
For the third, test by only using Electrical commands for several seesions.
You may have a faulty connection to the network and the DB Service is timing out. This could be as simple as a damaged network lead to as complex as a faulty switch. I had problems with a switch that had faulty ports that was affecting several systems only. Kept getting timeout errors but when tested, everything seemed fine.
Regards Brad
Brad Coleman, Electrical Draftsman
pmccutcheon
Re the network - the catalog .MDB is on my C drive (not networked); the scratch database is also on C: drive -- what else is there?
Icemanau
Those are the ones that I am aware of. Hopefully someone else will be able to help more.
Regards Brad
”Boost
