Hi there,
I´m experimenting with P&ID drawings and would like to know if I can have Autocad Electrical somehow integrate the layername into to the tagname. I have read that the replacable parameter %G is for the wire layer name but this doesn´t work. For instance if I create a wire layer with the name "4" and set my drawing propertis for component tagging to "%F%G%N" then I would have expected that the components would be tagged as an example -RT401 whereas the family is RT, layer name is 4 and the first component number is 01.
The result I´m gettin is instead -RT%G01 ??
Any suggestions gentlemen?
Thx. Gary
