AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
TAG does not update in reports
2 REPLIES 2
375 Views, 2 Replies
I will try to expose my problem clearly:
I rename a component TAG (for example TL02 become TL01) then I save my drawing.  When I run a report, like BOM or schematic list (Panel) or Missing Catalog date, the TAG is not update.  Sometime, I close completly the project and run again the report and it working.
Do you have any idea of the problem?  Should I have to run another command before running the report?
thanks
Francis
2 REPLIES 2
testsubject
First question I would ask is how are you renaming the tag: do you use Edit Component or Just double click and use the Attribute editor. If it is the later, the database is not updated and will definitely present what you are seeing.
If you do use the Edit Component, sometimes the database is not updated. When this occurs, you need to save the drawing and then run AEREBUILDDB to update the database.
This command is not available on any of the tabs but is easy to add using CUI.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
in reply to: testsubject
thanks for the rapid answer!
I always use edit component.  I will try this command and let you know
thanks again
”Boost
