AutoCAD Electrical Forum
Tabular terminal strip table object
2 REPLIES 2
432 Views, 2 Replies
Is it possible to add a data field into the table object, specificaly %P. I use this in my cross referencing, and want it to be shown in my terminal tables because my cables run between projects.
2 REPLIES 2
rhesusminus
Hi David.
As far as I know, you're not able to add custom fields to the available fields for a tabular termnial strip objec 😞
Anyway, what IEC Project Code would you want? The IEC Project Code for the sheet where the terminal is drawn, or the IEC Project Code for where the cable part is drawn?
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
in reply to: rhesusminus
Thats a shame, it would have been helpful. I would want the the IEC code of the drawing where the cable is drawn, or perhaps the device that the cable is connected to. Thanks for your reply Smiley Frustrated
”Boost
