Is it possible to add a data field into the table object, specificaly %P. I use this in my cross referencing, and want it to be shown in my terminal tables because my cables run between projects.
Hi David.
As far as I know, you're not able to add custom fields to the available fields for a tabular termnial strip objec 😞
Anyway, what IEC Project Code would you want? The IEC Project Code for the sheet where the terminal is drawn, or the IEC Project Code for where the cable part is drawn?
Thats a shame, it would have been helpful. I would want the the IEC code of the drawing where the cable is drawn, or perhaps the device that the cable is connected to. Thanks for your reply
