Hi, I recently installed Autocad Electrical 2014 but do not need it to produce full wiring/schematic diagrams. Is there a way to upload/create a library of simple lighting symbols i.e. emergency bulkheads etc? Our clients only reuire very simple plan view drawings showing the locaion and type of each light fitting
Any help appreciated! Thanks
Solved by rhesusminus. Go to Solution.
Yes, you can create all the symbols you need to accomplish your task.
The symbols are created using Symbol Builder. See the help file or take a class on how to use it.
