AutoCAD Electrical Forum
Symbol Library Pointer After 2012 to 2013 Update
6 REPLIES 6
2624 Views, 6 Replies
I have installed the latest AutoCAD Electrical 2013 after using 2012.  I have made a few symbols and I find the default file path attempts to place any new symbols in the 2012 directory.  Where can I change the default library location for new symbols?
Casey
6 REPLIES 6
RobinShou-Autodesk
Try to change the symbol lib path for your activated project in project manager should help. As the symbol build default file path is the same as the symbol lib path for your activated project in project manager
Robin Shou
Quality Assurance
AutoCAD Electrical
in reply to: RobinShou-Autodesk
Thank you Robin.  That resolved the problem.  Could you please communicate this issue to the developers?
I am guessing I may have used a prior project as a template and version 13 did not recognize the prior paths were based upon an older version.  It would be nice to have a pop-up noting the template is based upon an older version.
Thanks again,
Casey Heater
RobinShou-Autodesk
Sure, we will consider the issue in future.
Robin Shou
Quality Assurance
AutoCAD Electrical
How do you install additional PLC'S to ACAD Electrical 2013 (other brands or legacy)
testsubject
Use the PLC Editor, just like in all the other versions.
You should start a new thread for this question instead of highjacking a completely unrelated thread.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
where can I find the symbol library for surveying in 2013
”Boost
