AutoCAD Electrical General Discussion
casey.heater
Message 1 of 7 (2,199 Views)
Symbol Library Pointer After 2012 to 2013 Update
2199 Views, 6 Replies
04-10-2012 05:14 PM
I have installed the latest AutoCAD Electrical 2013 after using 2012.  I have made a few symbols and I find the default file path attempts to place any new symbols in the 2012 directory.  Where can I change the default library location for new symbols?
Casey
Employee
RobinShou-Autodesk
Message 2 of 7 (2,193 Views)
Re: Symbol Library Pointer After 2012 to 2013 Update
04-10-2012 08:45 PM in reply to: casey.heater
Try to change the symbol lib path for your activated project in project manager should help. As the symbol build default file path is the same as the symbol lib path for your activated project in project manager
Robin Shou
Quality Assurance
AutoCAD Electrical
casey.heater
Message 3 of 7 (2,152 Views)
04-16-2012 07:30 AM in reply to: RobinShou-Autodesk
Thank you Robin.  That resolved the problem.  Could you please communicate this issue to the developers?
I am guessing I may have used a prior project as a template and version 13 did not recognize the prior paths were based upon an older version.  It would be nice to have a pop-up noting the template is based upon an older version.
Thanks again,
Casey Heater
Employee
RobinShou-Autodesk
Message 4 of 7 (2,149 Views)
04-16-2012 07:38 AM in reply to: casey.heater
Sure, we will consider the issue in future.
Robin Shou
Quality Assurance
AutoCAD Electrical
New Member
gatwood
Message 5 of 7 (1,978 Views)
06-28-2012 06:43 AM in reply to: casey.heater
How do you install additional PLC'S to ACAD Electrical 2013 (other brands or legacy)
testsubject
Message 6 of 7 (1,974 Views)
06-28-2012 07:46 AM in reply to: gatwood
Use the PLC Editor, just like in all the other versions.
You should start a new thread for this question instead of highjacking a completely unrelated thread.
Bob Hanrahan
Ace User since 1998
New Member
ray.hebert
Message 7 of 7 (1,271 Views)
Symbol Library
01-08-2013 02:59 PM in reply to: casey.heater
where can I find the symbol library for surveying in 2013
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
