AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Symbol images for the catalog browser
12 REPLIES 12
Message 1 of 13
rhesusminus
647 Views, 12 Replies
Hello Autodesk.
I've tried to read the help files to understand how the images used for a SYMBOL2D block in the catalog browser is created.
I notice the following:
  • there's created a subfolder in the symbol library folder, called "Images", where it creates these images.
  • The format is JPG, not PNG as we're used to.
  • All images created for my symbols are just completely white.
So, what are the "rules" you have to follow, to create usable images for the catalog browser?
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
12 REPLIES 12
Message 2 of 13
drathak
in reply to: rhesusminus
Is this after an uprgade?  What version?
Joe Weaver
Principle Associate Engineer - Nashville Electric Service
P&C Committee Chair – SDS Industry Consortium
Message 3 of 13
rhesusminus
Forgot to mention, this is 2015. The catalog browser is a new feature I'm looking at.
Trond Hasse Lie
Ctrl Alt El
Message 4 of 13
jalger
Hi Rhesusminus,
I'm not Autodesk (,but I do work in the Reseller Channel).
The Images are generated based on the Symbol2D Column that was added to the Database, the symbols3D is what it shows when inventor accesses the catalog database.
The text in Symbol2D seems to look at the actual DWG in the symbol library, then it generates a JPeg of the dwg (I'm not sure why they needed to create a jpeg). the colour of your background seems to affect the outcome.
Not sure why you are seeing an all white background, maybe its not pointing to a block in the symbol2D Column?
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
Message 5 of 13
rhesusminus
Clicking the image inserts the correct symbol. I use black background.
Trond Hasse Lie
Ctrl Alt El
Message 6 of 13
jalger
Hi Rhesusminus,
Try Generating an image with Wblock or through the symbol builder and use that in the Symbol2D Column.
It was working for me when i did it that way.
James
James Alger
Work:
1tb SSD, 64GB RAM
Message 7 of 13
rhesusminus
Can I just use the png-files that the symbol builder create, or do I have to convert it to jpg?
Anyhow, I was really thinking about getting Autodesk to tell me the workflow here, and what they are thinking.
Manually creating jpg's for every symbol I create is "not an option" 😄
Trond Hasse Lie
Ctrl Alt El
Message 8 of 13
jalger
Well the Catalog Broswer is supposed to speed up the placement of components.
If you know the Catalog number or a general Description of the part your looking to place in it finds it Faster then placing a component and doing a lookup afterwards.
The reason its faster is because it puts the catalog data in when its dropped in.
So its like the footprint lookup database in a way. (but it doesn't have its own Database)
It seems to generate the JPEG on its own, I'm not sure if you can make use the png instead.
I think most of the symbols should work, I had to restart the program for the Database changes to showup,
but I was able to add the symbols.
I hope this helps,
James
James Alger
Work:
1tb SSD, 64GB RAM
Message 9 of 13
mathalekar
in reply to: jalger
The catalog browser images are generated on the fly and stored in respective lib folders. The mechanism to generate snapshot is similar to what it uses for drawing preview. Now the reason behind generating these snapshots is for performance in showing the preview images when using catalog browser. As a end user you do not really have to bother about format or type, background etc. as AutoCAD electrical does it's job silently for it's required function. These blocks are read from SYMBOL2D column if already there in the catalog assigned. If it is not there you have few very easy options to assign.
This mechanism is pretty similar for inventor and 3d file names are assigned in Symbol3d.
Message 10 of 13
rhesusminus
in reply to: mathalekar
Hi mathelkar.
WHen is the image-generation triggered? When "closing" edit mode in the catalog browser?
Will this regenerate all images, or just changed images?
How can I trigger a regeneration of all images?
Do you have any idea why I only get white background image, and in this case, just graphics that's not placed in layer 0? (see attached original symbol, jpg created by catalog browser and png created by the symbol builder)
Trond Hasse Lie
Ctrl Alt El
Message 11 of 13
rhesusminus
Thanks for reminding me that this hasn't been "solved" Autodesk 😄
Still wondering what happens here. As you can see here, the images in the catalog browser are pretty much useless as preview images.
So, is there another way to get better images? Write a script that generates the images?
Trond Hasse Lie
Ctrl Alt El
Message 12 of 13
mathalekar
Hello Trond,
The image generation is triggered when you access the record to select and use for insertion in the drawing. If the symbol assigned is something more custom symbol (or more like a small circuit) like, then i can see the symbol preview is not a good one like your. I shall take note of the case at my end and see if there is any workaround. You should be able to get preview if you generate preview and put it in images folder in libraries. It bit uncommon to us to practice & test this workflow to check viability.
Message 13 of 13
rhesusminus
Found the problem!
Layer 0 was set to color 255, not 7.
Kind of hard to see the difference between light grey and white on the dark bakground.
Changed the backgrund color to white to see if that made any difference, and THEN I suddenly saw the problem 😄
Trond Hasse Lie
Ctrl Alt El
”Boost
