Has anyone answered this yet? I have this problem and adding folders to the "Support File Search Path" does not fix it.
Did Pat Murnen mean the paths in the WD.env? I am using AutoCAD 2018 Electrical
I think she was referring to the library paths that are located in the Project Properties
Your symbols have to be in a folder listed in this list for ACE to find them.
Go to: C drive>users>public>documents>autodesk>acade>libs>jic125.
I hope this will solve your problem.
I am looking for the location of the file below. It is not in the JIC125 folder, which is where I thought it would be. It ever shows the file types of any new ones that I create.
You should look once more.
It's the files named AT_*.DWG
I finally figured it out.
EX: AT_HP_FU is the attribute mapping for a Horizontal Parent Fuse.
One question left. It now shows up in the list, but how do I edit the name. I copied th DWG for AT_HP_FU and renamed it AT_HP_HTR for my heaters, and it shows up as (HTR)HTR
How do I get it to show up as (HTR)Heaters?
Open your DEFAULT_CAT.MDB, and go to the _FAMILY_DESCRIPTION table.
Add HTR with a description there:
