AutoCAD Electrical Forum
Symbol Builder - how to create two terminals that are internally jumped
2 REPLIES 2
pwk
431 Views, 2 Replies
I am using AutoCAD Electrical 2014.  I have used Symbol Builder to create a symbol that represents a component I use frequently.  In this symbol, I created two wire connection points with the following attributes....
(1) X4TERM01; TERM01
(2) X4TERM02; TERM02
...In this component, these two terminals are internally jumped.  Therefore, when I use this symbol, if I draw a wire going into TERM01 and then another wire coming out of TERM02, these two wire segments should have the same wire number.  The way that I have created the symbol, AutoCAD is treating these as two separate wires and it complains when I try to assign them the same wire number.  I was wondering if there is something I can do inside my symbol that would make AutoCAD aware that these terminals are connected so that it will automatically use the same wire number for any wire going into or out of either of these terminals?
Thanks in advance,
Paul
2 REPLIES 2
Icemanau
in reply to: pwk
Easy way to do this is to change the terminal numbers...
For example...
(2) X4TERM01; TERM02
This will pass the wire number from the first connection to the second connection with no problems.
You should also get the two different terminal numbers for the differing connection points.
Regards Brad
Brad Coleman, Electrical Draftsman
rhesusminus
in reply to: pwk
Are you using the WD_JUMPERS attribute to create the internal jumpers, or do yo use the internal jumpers tool, that creates the VIA_WD_JUMPERS Xdata?
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
”Boost
