AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Symbol Auto Fill Attribute
5 REPLIES 5
MTSII
818 Views, 5 Replies
I am creating a symbol (Profibus I/O block) and need to have a field (per port, 8 total) that can be populated similar to a PLC I/O. ie. Starting Address(X0.0), Octal or Decimal etc to auto fill the tags. I haven't found any details of how to do this during symbol creation. Anyone help?
5 REPLIES 5
OP21
in reply to: MTSII
Have you explored the options within the PLC Database Editor?  You may be able to use a parametric build for your I/O card.  I've used this in the past to create Serial Communication cards with 2 ports (addressable points) and terminals with pre-assigned fields...
This may point you in the right direction...
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
MTSII
in reply to: OP21
I don't want it to look like a PLC I/O. I want it to look like a component I have drawn (see attached). There must be an attribute to call up that allows sequencing, example:- %%X, %%X+1, %%X+2 etc.
Any ideas
electricman1
in reply to: MTSII
This should be possible. Add a parametric PLC with similar i/o and explode it. Then scoot and edit the attributes as needed. Then re-block it and I believe the block name has to start "PLCIO" in order for the ACADE editor to recognize it as a PLC.
testsubject
in reply to: electricman1
Electricman1 has i right. If you name the symbol PLCIO-[filename] then ACE will treat it like a PLC and allow you to have I/O values auto number.
Name your attributes TAGA## where ## is sequential 01 to (highest count). When you edit the symbol, the PLC dialog box comes up and you can just edit the first i/o and the others will auto number.
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
MTSII
in reply to: MTSII
Thank you Gentlemen, that work just fine
”Boost
