Using AE2012. I'm having an issue with project wide updates. I'm using swap a block as an example. The only project wide feature that is working currently is the title block update.
What is happening is that when I select, for example, a block to swap and then select project wide and the specific drawings to proces, AE does the first drawing only, then stops.
Has anyone else experienced this?
Hello
You question caught my interest as I have had considerable issues learning this program.
The command does work for me as I had some time and did a test. I have had problems with this in the past and not bothered with this feature.
I ticked "do all" and it is very slow. I am on ACE2012 64bit i7 processot 8gb memory.
see added screen shot as this is what I use.
My drawing set is not large and I would normally do it sheet by sheet due to the slow implimentation of the update command.
I did not test if it would swap with a different family.
cheers jq
That is strange.
I just ran a small test and inserted a single soleniod on 3 seperate drawings and then used swap block and selected a different solenoid from the menu and had no trouble updating the 3 drawings.
Are you pulling the drawings from across a network? That will slow things down during project wide functions. It usually is still managable though.
Thanks for the replies guys.
It turns out that our CAD administrator had recently added some start-up routines that were interfering with the software. As soon as he removed them, I got full functionality back. I guess that's what you get for having a piper as administrator! 🙂
So problem solved.
