I have a push button on the schematic, and a push button foot print on the panel diagram - the linked worked ok
I have updated the push button symbol slightly on to a different layer
and the link has stopped working
anything obvious?
Steve
It could be because you moved it to a different layer. ACE expects component and component parts to be on specific layers based on the layers defined on the Drawing Format/Define Layers tab of the project properties. If the layer you moved to is not in this list, it may have adverse effects. Maybe Pat or Doug can chime in...
I never deviated from the defaults so never saw this problem.
everything else working ok - terminal strip editor/reporting
also noticed surfer not working on terminals themselves - i.e. going to the footprint
i get a database error = File '_YES.dwg' is inaccessible.??
Steve
Now you are getting beyond me. Maybe someone else can chime in.
