Sorry, I misread the original post. I was thinking of the Surf button on the
toolbar which in earlier versions of AcadE is greyed out when the active
drawing is not part of the active project.
Sorry for any confusion,
Pat Murnen
"Doug McAlexander" wrote in message
news:5803136@discussion.autodesk.com...
You did not say what version of ACADE you are using, but in the recent
versions there is a "Go To" button from the Electrical Audit dialog. You
select the error you want to surf to and click Go To. In earlier versions
you select the error and click Surf. I think Surf stays greyed out until
you select one of the errors from the list.
wrote in message news:5802914@discussion.autodesk.com...
Can anybody let me know, when will be the Surf button of the Report:Audit
dialog box available. I mean when can i use this button and when it will be
available.As i have seen most of the times it is greyed out.
Thanks in advance
Shaffy
