AutoCAD Electrical General Discussion
Active Contributor HAZ
Active Contributor
0 Kudos
Post 1 of 2
Suppress Wire Collision Check ON/OFF
162 Views, 1 Replies
04-18-2010 11:06 PM
Hi
Is it possible to set "Suppress Wire Collision Check" ON/OFF in the same session without leaving the Autocad Electrical 2011?
Regards Hamid Z
HAZ
150 Kudos
Post 2 of 2
Re: Suppress Wire Collision Check ON/OFF
04-19-2010 08:37 AM in reply to: HAZ
Hi Hamid.
I'm not quite sure what you mean here. The Suppress Wire Collision Check IS set within the current session, inside the Insert Wire command. If you Exit AcadE, it's turned on again.
If you want it to always be default off, you could always add this line to WD.ENV:
SETQ:GBL_wd_skip_collision_check,'1
THL
Trond Hasse Lie
ECAD Consultant, CtrlAltEl
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
