AutoCAD Electrical Forum
Suppress Wire Collision Check ON/OFF
1 REPLY 1
365 Views, 1 Reply
Hi
Is it possible to set "Suppress Wire Collision Check" ON/OFF in the same session without leaving the Autocad Electrical 2011?
Regards Hamid Z
1 REPLY 1
rhesusminus
Hi Hamid.
I'm not quite sure what you mean here. The Suppress Wire Collision Check IS set within the current session, inside the Insert Wire command. If you Exit AcadE, it's turned on again.
If you want it to always be default off, you could always add this line to WD.ENV:
SETQ:GBL_wd_skip_collision_check,'1
THL
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
”Boost
