I often run into situations where a drawing setting is changed and this setting should have been copied to the project settings. I realize there's a "Settings Compare" function, but this function becomes arduous to run on every drawing.
AutoDesk,
Please set up a "monitor" function that checks for drawing / project setting differences automatically. The user could then be asked if they want the drawing setting applied to the entire project. Once those differences are acknowledged and accepted, the system would ignore them until a setting is changed again.
Casey H.
