AutoCAD Electrical General Discussion
Distinguished Contributor
fdna49
Message 1 of 2 (71 Views)
Sub-assemblies
71 Views, 1 Replies
03-16-2004 11:41 AM
I am trying to assign a part to a female plug with the male plug as a subassy.
Both plugs have different part numbers since at times they may be used individually.
I cannot get the subassy part to show up on any report, so I don't think it is there.
Can Anybody help?
Chad
MartinLee
Message 2 of 2 (71 Views)
Re: Sub-assemblies
03-16-2004 12:05 PM in reply to: fdna49
Chad,
You have to use assembly codes, which are user-defined. When you put in the catalog info for your female plug, down toward the bottom of the dialog box are two boxes, one labeled "As main->sub", the other labeled "As sub". For the female plug, you put some code that helps you identify the sub-assembly (sometimes I use part of the sub assembly's part number), then add the catalog info for the male plug, and put the exact code in the "As sub" box. Now, when you assign the catalog number, they will be matched up. If you wish to see all of the sub-assembly numbers, there is a button to check (Sub asmb vals in pulldowns.) which is just above the Quick BOM Chk button. You can have multiple sub assemblies, as long as all the same "As sub" code.
CLear as mud???
Martin
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
