I created:
HA7S1_REF.DWG - (SOURCE)
HA7D1_REF.DWG - (DESTINATION)
I insert both into the same drawing, it works fine. When insert the source into sheet2 drawing and the destination into sheet 16 drawing and they won't update. If I insert the source into sheet1 drawing the destination WILL update on sheet16.
If I insert a relay coil into sheet2 drawing and a contact into sheet16 drawing, when i go to assign the parent coil, it is not in the list. I click on freshen and still won't find the coil.
it seems to me my project won't find anything on sheet2 drawing. all cross refences from sheet2 to sheet2 are working properly. all the drawings are in the same project. I'm running acade 2006.
