Tracy,
I don't have access to this by case id. So if you want to have the end user
contact me directly with the details and files, my email is
pat.murnen@autodesk.com.
Pat
wrote in message news:5825229@discussion.autodesk.com...
Pat,
Thank you for the offer, but I had the end user log this problem with his
reseller's technical support personnel. They assigned a case #: 299-14445:
spreadsheet - PLC utility address number.
They were able to get the I/O addressing scheme to work from a generic
spreadsheet, but not from the end users original spreadsheet. They never
stated what the actual problem was with his original spreadsheet.
If you can't find out any specifics (or that case number is the reseller's
internal number, not Autodesk's) then let me know and I will have the end
user contact and send the working and non-working spreadsheets directly to
you.
Thanks again.
Tracy Lincoln, TLConsulting
Autodesk Discussion Group Facilitator
