AutoCAD Electrical General Discussion
Member
0 Kudos
Post 1 of 2
SS to Generator
69 Views, 1 Replies
02-05-2004 01:13 PM
How do you fix the spreadsheet for an analog output module to wire a closed loop output device ? Everything we have tried results in the module being drawn with the terminals connected to the +24 volt rung - no problem with the analog input components.
*Nate Holt \(Autodesk\)
Post 2 of 2
Re: SS to Generator
02-06-2004 07:12 AM in reply to: randy
Randy, This may or may not address your question. Take a look and let me know. Go to Chapter 5 on the Electrical Help Topics on-line help > Spreadsheet to PLC I/O Drawing > Spreadsheet/Database Format. Look at the "Special Wiring for In-Line Components example of doing a closed loop. If this is not what you're looking for, please email me an example (n8holt@cs.com). Nate. "randy" wrote in message news:22873613.1076032514416.JavaMail.jive@jiveforum1.autodesk.com... > How do you fix the spreadsheet for an analog output module to wire a closed loop output device ? Everything we have tried results in the module being drawn with the terminals connected to the +24 volt rung - no problem with the analog input components.
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
