I am having problems with the spreadsheet to plc io utility.
Problem #1:
My current setup is set to insert 3 devices on an AB 1756-OB16E module (terminal/relay coil/terminal). The spreadsheet has been modified to include CAT and MFG data for the devices. But, when the utility runs, it seems to ignore the "pinlist" and "terminal properties". If I insert the terminals manually, the catalog data dictates a multi-level terminal, but when I run the utility this info is not there, but the CAT and MFG data shows up. With the relay coil, I have the same problem, but its missing the pinlist info. Again, it shows up if I insert it manually. Is there a way to get this to generate my schematic page with devices that have all their information?
Problem #2:
When I insert a PLC module that requires a break, the "TAG_1" attribute on the child comes in really small and out of position. If I insert this same module manually, everything comes in perfect. Is there a solution for this?
Big thanks to anyone who can help with this.
