I have a problem with the wire numbers in plc I/O layout. When I used spreadsheet to PLC I/O tool to generate a PLC I/O layout, I got the drawing wn1.pdf(see the attached), the wire numbers for each I/O are shown on the drawing. But when I deleted the terminal TB1 & switch HS100BS from spreadsheet for the input I:002/01, the location of wire numbers have been changed. The wire numbers I:002/00 & I:002/01 are shown on the left side of terminal TB2, and I:002/02 & I:002/03 are shown on the right side of the TB2 (see drawing wn2). Could anyone tell me what happen here? I only deleted two devices in the spreadsheet. another question is: how can I get rid of wire connection between two terminals, when generate PLC I/O from spreadsheet( modify _wdi or _wdio files? how?).
Thanks in advance,
Lena
