Solved by MTSII. Go to Solution.
One item to note when using the TSE:
If you make a change to the terminal strip after ballooning all the items (like adding or removing a terminal) you will have to re-balloon the strip when done because the balloons don't match up anymore. There is really not much you can do about it just something to be aware of...
Just be sure to add the appropriate end stops, end plates/dividers and other required accessories at the break point. This will then include those extra components and give you a better visual guide on what footprints to move.
Regards Brad
Brad Coleman, Electrical Draftsman
