AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Split Terminal Strips and the TSE
1 REPLY 1
213 Views, 1 Reply
In ACADE2008, is there a way to show a terminal strip that is split into 2
groups using the TSE? Or is moving the terminals after the TSE has inserted
them the only way?
Regards Brad
1 REPLY 1
Gaituuth
Hi Brad,
If you are using the graphical terminal strip then the answer is No.
The same for the Tabular Terminal Strip but this is solved in the 2009 version.
Regards Gerald
”Boost
