AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Source destinaton arrows...
7 REPLIES 7
Message 1 of 8
CAD-ICE
747 Views, 7 Replies
Hi there,
I have an issue when inserting source/destination arrows.
For some reason my ACADE (2012) inserts previously defined symbols instead of the standard symbols that are delivered in the IEC2 library? Even if I use the symbol update block tool I still get the wrong block on my drawing (see attached picture). There must be some sort of setting where it´s defined what block the software uses...but I cant seem to find it. In my drawing properties I have set the arrow style to 1 for your information.
Thanks and regards, Gary
7 REPLIES 7
Message 2 of 8
dougmcalexander
in reply to: CAD-ICE
Update block will only work when the block name is exactly the same.  Delete all arrows and purge the drawing of all unused blocks.  This should allow fresh symbols from the assigned library to be inserted.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Message 3 of 8
CAD-ICE
in reply to: dougmcalexander
Hi Dough,
I have tried what you said that is deleted all arrows and purged the drawing but still with the same result!
I have double checked the library path and the path´s are in order. So that´s why I´m confused...?
Attached is one of dwg´s from the project I´m working on.
Thank´s again for looking into this.
Regards, Gary
Message 4 of 8
dougmcalexander
I ran the update block utility and it replaced your arrows with the ones from my IEC library.  Someone must have changed the symbols in your library folder. Drawing attached.
Doug McAlexander
Message 5 of 8
CAD-ICE
That is really somewhat unbelievable? I have tried the same thing even on several IEC2 libraries from different versions that I´m certain of being original symbols. I alway´s get the same result, the refererence is ok, but no arrows?
Thank´s again and regards, Gary
Message 6 of 8
dougmcalexander
We are dealing with computers here.  It's amazing that the richest man in the world got there with an imperfect product.
Doug McAlexander
Message 7 of 8
CAD-ICE
Hi again Dough!
for some reason when I was updating the symbol the old symbol pointed to a library path from another project?
I didn´t notice it since the path was wery similar to the default path in this project.
Sorry for dragging you into this...and thank´s again for helping me out.
Regards, Gary
Message 8 of 8
dougmcalexander
No problem Gary.  I'm glad to help.
Doug McAlexander
”Boost
