AutoCAD Electrical Forum
source Destination Arrow Prompt
4 REPLIES 4
Burnett-al
503 Views, 4 Replies
Could someone tell me how to change the prompting for the destination arrow.  I placed the source arrow and checked the don't ask me again box on the destination arrow prompt.  I need to get this prompt box back.  It makes it difficult to place destination arrows when you have to go back in and manually add them on the same drawing.
4 REPLIES 4
Burnett-al
in reply to: Burnett-al
Figured it out.  Just need to restart the computer and it fixed the issue.
hpenza
I need fill arrows desc fields w/crossed CMP:PIN from/to destinations
help me
Icemanau
in reply to: hpenza
Description fields require you to manually type in what you need the description to read.
There is no function to automatically fill in the description as this can vary.
It can be as you requested all the way through to a nonsense description that has nothing to do with the wire at all.
Most people place a description of the wire function (110V +DC TRIP SUPPLY as an example of one that I use a lot) rather than a component pin.
Also, in future questions, please indicate what release of ACADE and O/S that you  are using.
It gives those that are trying to help a better place to start when they try to answer the question.
Two similar problems in two releases may well have totally different causes and remedys and knowing the release from the start will help getting the right answer quicker.
Regards Brad
Brad Coleman, Electrical Draftsman
hpenza
in reply to: Icemanau
We really need to fill all the descriptions of the signal arrows with crossed CMP:PIN field of the Wire from/to report.
It take too much time to do that manually.
There is all the information in the database.
Wiring people ask for that. Maintenance people ask for that here.
They said that is very important to have crossed CMP:PIN labeling because you can follow the circuit without schemes.
In maintenance and emergency maintenance you don't have time to find the schemes. Then they want to find a problem following the wiring. Because of that my company requires that.
All the people that works in maintenance prefers crossed CMP:PIN labeling
[cid:265203013@17112014-36EC] [Bandera de Uruguay]
Thermal Power Stations Studies and Maintenance Department
Map:: http://maps.stcstm.org/?lat=-34.886186&lng=-56.196286&zoom=18&type=h
UTE website: www.ute.com.uy
Photo: http://r6---iad23t06.c.bigcache.googleapis.com/static.panoramio.com/photos/original/56077365.jpg?ms=...
”Boost
