AutoCAD Electrical General Discussion
New Member
0 Kudos
Post 1 of 1
Source/Dest. Arrows with source & destination
28 Views, 0 Replies
06-09-2005 03:36 PM
Is there a way to have the source and destination arrows show the device and pin number the signal is going to/coming from along with or in place of the wire number?
I've noticed in the Terminal Block Editor, they use a %Q:%P code to display wire destination information in a terminal layout, and it would be nice if I could have something similar to this appear as part of my off-page references, since you can see where the wire is going/coming from without actually needing to look at the destination sheet.
Thanks.
Andrew Hand
If %Q:%P won't work, is there a way to display the wire connection sequence on the drawing as, text, an attribute or part of a wire number?
Post to the Community
New Post
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
